Hi guys,
My uncle bought a '97 40th anniv edition about 5 days ago, and it quit running the next morning. We've spent hours on mud while troubleshooting the problem, and are approaching a dead end. We could sure use some help. Here's the situation:
Truck has undergone an engine swap. It's the correct engine for the rig, but the vin is different. Odometer reads just below 200k. During the PPI it started and ran wonderfully several times, when cold and when warm. No codes. It ran wonderfully for the 80 miles home, as well as for half a dozen trips around town later that day and the next morning. Then it wouldn't start. It cranks strong, but won't fire. We've reviewed the FAQs on "no start emergency procedures" and more than a dozen other threads. Here's what we've tried:
Tested:
- fusible links: 12.4 volts getting through even while wiggled to test for intermittent failure.
- brass bolt head in under hood fuse box: 12.4 volts
- all fuses in the panel left of the steering wheel and under the hood look good.
- wiring harness under engine bay and below steering column appears unmolested.
- EFI relay, Fuel Pump relay, and that relay down in the kick panel that is identical to the efi relay (can't recall the name) have all been swapped into my '97 cruiser with my relays swapped into his. In all cases, my truck continued to run while his continued to not start). Relays appear good.
- disconnected air intake after MAF and sprayed a bit of starter fluid in the intake while cranking. The fluid combusted. We definitely have spark.
- disconnected fuel pressure regulator return line. NO FUEL came out, even while cranking. Ok, now we're getting somewhere.
- Fuel filter appears to be a correct, new replacement likely installed with the engine swap. Made in China, but correct.
We had to let it sit like this for a few hours while dealing with life. My uncle reports that once during this time, while the fuel return line was disconnected, the truck started and idled smoothly for about 25 mins. Then he closed the door and it shut down instantly. Clue?
We went back to the fuel pump. 12 volts to the red line, around 2.5 volts to the blue line, but pump is inoperable. Pump appears original. Time to throw money at it: replaced fuel pump and tank gasket with Denso replacements from amazon. No improvement.
Now we're a bit baffled. I have a few suspicions, but would sure appreciate some suggestions:
1. Factory alarm... the window sticker indicates it came with a factory alarm. The aftermarket stereo includes an amplifier installed beneath the driver seat. Per reading on mud, I believe this is where some of the alarm electronics were installed on 97s. Could this cause our symptoms? If so, how do we proceed?
- ECU?
- MAF... could a bad MAF sensor cause the truck to not send fuel? Our symptoms are inconsistent with MAF issues I've addressed on European vehicles.
We could really use some help on this one. Any ideas or suggestions would be very much appreciated. If we can't figure it out it'll have to go to a mechanic, but the first thing they'd do is repeat everything we've already done. We live in a fairly small town without a cruiser specialist, so the closest thing we have are indies and the Stealership who puts the St in dealership (I know, not all dealers are this way, but ours is). Hopefully it doesn't come to that. Thanks in advance.
Tested:
- ECU?
