Truck history:
Complete axle rebuild about 15k miles ago. Wheel bearings are nice and tight, no play in wheels.
Truck sits about 2.5-3" above stock, and caster is corrected and was measured at 2.6 deg with blue bushings.
A couple of months after I lifted my truck I started getting a slight vibration at around 65 mph while coasting, accelerating, and decelerating.
I read up in the forum and started by pulling the front shaft. What do you know, the vibration is gone. One of the u-joints was a little notchy so I installed new toyota u-joints and had the shaft straightened and balanced. Made sure this was done with the shaft at 90 deg out of phase.
Installed the shaft and the vibration was still there. So then I pulled the rear shaft and noticed one of the u-joints was also not very smooth. When I drove the truck without the rear shaft the vibe was gone. Replaced the u-joints and had the shaft straightened and balanced. Bolted up the shaft expecting the vibration to be gone but it is not.
I still have vibrations at about 65-70 mph mostly when I am decelerating. The vibration is mostly audible and not something you can really feel. It sounds like when the truck goes on the highway rumble strips that wake up sleepy drivers but not nearly as loud.
Where do I go next? I am pretty anal about maintenance and how my truck runs so I really want to sort this out.
wheels with stock tires on mine just to verify that indeed, it's not caused by something mechanical.
