My m416 refurb and build
Floor is in. Also finished the support plate where the new drawbar meets the old frame rails.
Great work Andy!
You putting the RTT on it?
Frame, fenders and rack are 100% done and waiting.
Tub painting in progress. Black Berliner inside and under. White enamel on tub exterior. This is just white primer.
Very nice Andy!
Great build ! Make sure you pat yourself on the back, that came out sweet....
Andy,
What are the details on your tires? Still running tubes?
I would also suggest changing out the wheels for Jeep wheels . This will allow you to use tires better suited for off-road use. The tires that fit the 16"rims are LT tires for a 3/4 ton or one ton truck .
These HD tires will not flex when aired down causing the trailer tires to bounce into the air off-road. With Jeep wheel you can fit an off-road tire load range "C" that will air-down and flex offroad. I use one of the 16 wheel/tires as a spare .
These 416's are so maneuverable by hand, even when moderately loaded that a wheeled jack stand is overkill. Of course, YMMV
Of course ,empty on a flat paved surface . Loaded and not in a driveway is a different story.
