- Joined
- Jan 16, 2015
- Threads
- 3
- Messages
- 22
I've been replacing hoses and compiled a hose reference for myself that may be of help to others. I got much of the information from other posts.
If you find an error please notify me so I can correct the list. Rear heater hoses aren't complete yet.
1996 LX450 Hoses
99556-30100 X3 100mm section of 16mm (.640”) hose that you cut down to 50mm for the PHH. The same part number is used in three other locations. The two parallel hoses at the back of the valve cover and the front heater inlet.
12261-66021 (12261) Hose ventilation (PVC hose)
12262-66021(12262) Hose ventilation #2 (PS valve cover)
87245-60340(87246B) HOSE, HEATER WATER, OUTLET B (PS s shaped Hose to the heater pipe to tee back at the firewall)
16264-66021(16264) HOSE, WATER BY-PASS, NO.2 (connects between hard line front of engine to front side of throttle body)
16261-66040 (16261G) HOSE, WATER BY-PASS, NO.1 (connects on the back side of the throttle body)
16267-66020 (16267) HOSE, WATER BY-PASS, NO.3 (from radiator to next to distributor)
16573-66010 (16573B) HOSE, RADIATOR, NO.3 (PS lower hose)
16571-66030 (16571C) HOSE, RADIATOR, NO.1 (DS hose)
16572-66021 (16572D) HOSE, RADIATOR, NO.2 (PS upper hose)
99555-10200 (16278D) HOSE, WATER BY-PASS, (connects to the end of the hard line running across the front of the engine and back side of water pump, cut to length)
87245-60480 (87245B) HOSE, HEATER WATER, INLET B
(DSHOSE to VALVE ASSY, HEATER WATER)
87245-60350 (87246A) HOSE, HEATER WATER, OUTLET A (with rear heater) Short hose from tee to the firewall
87245-60310 (87246A) HOSE, HEATER WATER, OUTLET A (without rear heater) Substitutes for 87245-60340 (87246B) HOSE, HEATER WATER, OUTLET B (PS Hose to the heater pipe back at the firewall)
87208-60350 (87208C) PIPE SUB-ASSY, HEATER WATER, C (rubber hose next to firewall not available separately from hard pipe, use 1/2” ID Gates 28460 Eng Coolant, Cut To Fit)
Cruiser Dan told me the 1/2 in. hose only comes with the assembly so I used Gates 1/2 in. 90 deg. hose 28460 and cut it to fit as shown below.
1996 LX450 Hoses
