My first motor pull
Southeast US
Yes, I mugged for the camera a bit. You have to entertain the wife whenever possible.
Technically, I didn't leave enough slack to be able to turn the leveler crank. It was nearly useless anyway with so much weight over the tail of the motor.
One thing I completely whiffed on was disconnecting the fuel lines. They are buried in there pretty good but there is still no excuse for that.
Untitled by Michael Harrison, on Flickr
Nice and gooey. It will be significantly cleaner going in.
I got the silicon PHH kit and the firewall heater lines coming. I will put the heater mixer on the list of things to get.
While I am there.....
Vacuum lines (3mm or 4mm silicon?? a search was ambiguous on that) 13mm green stripe heater hose for good measure.
I have a crawler gear set that I will take the t-case to ACC in Atlanta to install.
I will also have the head rebuilt. I plan on having the valves ground, valve guides and seals installed as well.
Looking good man! The engine, not the dude that photo-bombed your work! :)
If you're in the SW, now would be a great time to delete the rear seat heater. Mine was on the brink of goners, and my truck was a Houston truck most of it's previous life. I've been through a couple winters and don't miss it. I rarely carry rear seat passengers, and the dogs got their own coats they can't take off anyway, and they usually want the window down even if it's cold.
At least you didn't break off the distributor rotor (I did, heh).
Looking forward to this build - it's going to be sweet I'm sure!
By the way, the poor abused dog in your avatar, what is he? He looks a lot like our Rhodie-Dobie mix so I had to ask.
So I should R&R the t-case switches too? I can do that. I will inspect the tranny as well and see if it is all good.
blkprj80, it was a random internet picture find that I absolutely love. It is my FB avatar as well. I have no relation to the dog....
I have pulled two 2f engines out of fj60. Rebuilding my first engine and hopefully can put it back into a fj40 without any major issues. Time will tell. It's a lot of work. Good job.
You can pull the switches and clean em up and bench test them per FSM. I'm betting you won't have to replace em. Certainly easier to do than laying on your back catching dirt clods in your eyes.
I have a descent mechanical aptitude and a fair amour of experience. My 3 biggest jobs were 2 clutches on cars and glow plugs on an excursion.
It took me about 2 weeks total time and probably 10-12 hours not including home depot/harbor freight runs. It would have been shorter if I had pulled the AC condenser early in the job. The biggest time killer was getting the frozen exhaust nuts, prop shaft bolts and just dealing with the massive grime.
The hoist is a 2 ton hoist and is currently at the 1 ton pin. It worked fine not shown is how much weight is on the floor jack. I put the floor jack under the tranny and aligned it with the engine hoist. When I move the engine forward the jack just oooched forward really easily. I hope that technique works as well in reverse.
It looks like you filled the fender flare holes. What did you use to accomplish that? (Sorry to derail the conversation) I'm in the middle of a similar build.
I hope I am OCD enough to pass the audition with this crowd....
Here is my organization system. I put every bolt, nut, etc into a bag and I am hoping I labeled it well enough to help get them all back in the right spot. I am thinking if I leave a plastic bag with parts in it, I have left something off the truck.
Box of labeled goodies. by Michael Harrison, on Flickr
That is the organization system I used, and I was pleasantly surprised that when I finished, I had neither extra hardware, or any hardware missing. I took a million photos before I disassembled anything, and that certainly helped. Pulling the drivetrain with the engine was relatively simple, I can't see any reason not to do it that way. Good luck with your build.
That's the method I used. I put old business cards with names on them inside each bag. The only thing I wished I had done was labeled with a number of order. It might have saved a bit of time going back together. I pulled parts off randomly, so it may not have helped that much though.
When I did my Lex SC300 timing belt, I used the numbering system and it helped a lot.
When you pull the sensors and stuff of the left side, poke it into cardboard with a sketch showing where each part came from. That was helpful when I did mine.
Take lots and lots of pictures.
I dropped the T-case at ACC's new shop in Atlanta to get a new set of crawler gears installed. I love the new shop but didn't think to take pictures while I was there.
Wow. These 2 flywheel bolts were a pain. My 6 point impact sockets stripped the heads. I guess they are not quite as high grade as they looked.
Thank goodness I had these on hand. It was the first time I used these bolt-grips but they saved my bacon. I figured I would run into a few problems on the job with a 1997 car and this was the first occasion. It was worth every penny.
Saved by the bolt grips by Michael Harrison, on Flickr
I am starting my motor pull this weekend as well, I may need to share notes with you! :hmm:
