My dad doesn't think the 80 can haul...
About the Chevy transmissions, they are crap compared to an LC. My tranny (130,000) shifts and feels so much better and smoother than the 99 tahoe I had with 55,000(Shifted horribly and was about to need a rebuild). My dad continues to buy suburbans and says himself they need a rebuilt around 60,000 or 70,000. That is when he sells them :D
cruiserdan said:
Have you ever flat-towed anything before?
The 80 will handle the weight ok. Flat-towing can be spooky and remember stopping can get a bit odd at times. I flat-towed a crew-cab 2wd dodge truck behind a 1 ton 4WD Dodge truck 650 miles a few years ago. My Cummins handled the weight just fine but it got to be a handful to control over about 55mph. In addition the towed vehicle tried to "push" the back end of the towing vehicle while decelerating and turning. That was a spooky feeling.
I suggest you practice a bit first before you go out for real.
D-
Yes, actually quite a bit. I've been flat towing it for almost as long as I've owned it. And I was doing the driving, not my dad, in most cases. I've towed it on tight surface streets, open highway, hilly highway etc. Most any road type found in GA.
I appreciate the concern, but it is not necessary. :)
The 80 is heavier and has better brakes than all of the vehicles I have flat towed it with in the past. (aside from the POS suburban).
I was actually planning on a short test run the night before anyway. :)
Suggestions for Tow Bar Vendor?
Just read this thread and have a similar need. I have a stock 1977 FJ40 in South Carolina and need to get it to Atlanta occasionally so I can play with it. We originally trailered (borowed) it to SC with my son's Ford Expedition (he has since bought a LX 470) and it is about a 6 hour drive - all fairly flat. Driving the 40 to Atlanta would mean one LONG day on two lane roads - I just don't want to do it. I also don't trust the U Haul dollys and the straps won't close over the tires on the 40 anyway.
I have DDs - 1995 T100 and 1997 FZJ 80. The T100 is a 4 cylinder but too weak. Based on your posts about pulling with the 80 I would like to invest in a tow bar to make this run a couple of times a year.
Any recommendations on a good bolt-up tow bar to fit the FJ 40? Thanks.
