Those numbers are within the range specified by the FSM.bretty said:the engine was warm, maybe sitting for an hour or so after drivin for 20 mins. i havent adjusted the valves thats the next thing i gotta do on this new engine.
65swb45 said:IMO, the numbers are fair. The better question IMO is what kind of vacuum does the engine pull at idle, and on a 'mild' hill at 50mph.
I have seen engines with compression numbers close to yours that pulled 20" of vacuum at idle and 10 or better on a mild grade, which is very good. Those engines felt strong like they could last forever. I have seen other engines with those specs that had a hard time pulling 15" at idle, and you could feel it was weak from the getgo.
IOW, its not ALL about compression.
My .02
