My '94 towing question
Nashville
Ok, I need advice whether to get my 80 fully set up with a brake controller for my 5100# catering trailer, or set up my wife's 100 series for the tow. They both have hitches already. Thanks for the input!
no brainer, use the 100. especially with 285's on your 80.
x2 big time. Your 80 will struggle with 5100 lbs much more than the 100 series. Take it from someone that tows 3500 lbs pretty regularly with a '94 80 series!
Just got home from towing our 6000lb boat to a remote lake and back. With stock tire size and in good tune 5100lbs would be no problem. The truck is rated for 5000lbs in the US and 7700lbs in other countries with no mechanical difference (the reason is our nutty liability exposure which the Japanese are terrified of).
Will the 100 pull harder? Sure. But do you really want your wife's nice 100 in use during working hours every day and coming home every day smelling like fried food?
We've towed this boat around 14,000 miles over the years. I'd put Airlift springs on the rear ($100) and use a factory frame hitch. If you're doing hills, I'd lose the 285s due to their gearing loss, and if you're doing freeway speeds I'd also lose them in favor of a better tread pattern for driving control. Other than that, proper maintenance and you'll be fine.
DougM
I'll second Doug's recommendation on the Airlift bags in the rear coils. BIG time help from sagging.
Thanks. It also puts the truck firmly in control of the rear axle load. Over bumps and heaves the truck doesn't wallow or bound up and down - just small rubbery and controlled movements that make it clear the towing vehicle is in control vs the trailer being able to move it.
DougM
That is great advice, airlift springs. I am still thinking of getting OME heavy duty suspension. That would also obviously help the load capacity, but much more money than $100 airlift springs! My truck is also registered commercial for my business, so add ons and mods are a write-off! Thanks, guys.
My 80 has always towed my 5000lb boat without problems, but my 100 does it effortlessly. I'd go with the 100, as it's one of the relative advantages of the 100 over the 80.
T.
