Build My 2011 GX460 Build - Stay Classy SD
Member Build Threads
Too bad about the heated steering wheel not working, it’s one of the features I wish my GX had. Cool take on a build!
I did the rocker panels swapped today but I couldn't make the front 2 clips go in and it didn’t line up with the fender. Did you run into that problem.
Yes. The lines don’t perfectly match. The driver side of the rocker panel needs a little trimming to remove the clip holder - since the clip position isn’t right.
Also fits best with the prado front mud flaps. These tighten the whole front up.
Thanks for the reply! So you didn’t use the first clip and just tighten it up with the mud flaps? I have the mud flaps just haven’t put them on. I will try to do that tomorrow.
Yes. Don’t use the clips. Remove the clip holder on the driver side by cutting it off (gives more space to have the panel fit snug). Then put on the mud flaps.
