- Joined
- Oct 6, 2007
- Threads
- 1
- Messages
- 7
I'm new here looking for help-
My 1985 Toyota SR5 Xcab Pickup that I've owned since it had 5 miles on it, had issues today with the 22REC engine that has been smoking a bit lately and using a lot more gas than I think it should.(seemed to quit leaking oil and just burn it instead).
Today we got a very wet snow fall of maybe 4"-6" and while driving out to my shed/shop to work on a trailer I'm rebuilding the toyota seemed bogged down a bit and needed about full throttle in 4th to go 50-55 and I was trying to stay off the deep slush in the roads.
When I got there I pulled up to talk to a friend and after we drove apart I smelled antifreeze.
A few hours later I had to move it to load stuff for my girlfriend and later I was checking the oil and saw moisture under the hood above the overflow bottle so I looked into the rad and saw only the tops of the cooling fins and no coolant???
I then pulled the dipstick to check the oil and saw the tell-tail signs of coolant and oil mix of gray gunk..,
I need oil so I pulled the cap off and saw the same gray under it also!
I added the oil and desided to let it sit and ride back to town with my sweetie and research the possible causes of coolant and oil mixing???
This engine is stock and has only had the front main seal replaced and is at about 185K miles.
I hope its only the head gasket because it was running and don't think it busted thru in the block any place.
Yes my bed sides are about rusted gone, I painted the thing complete in 96 and because I use my truck and the body and frame get twisted around in the Rocky's, it breaks the stupid seal that was between the lower and upper bed sides on the early year models.
, drivers side hub has been an issue since the stock auto hubs failed and mechanic missed the clip that holds it all together and the thing has gone thru a hub on that side only about every two years.
!!!I then pulled the dipstick to check the oil and saw the tell-tail signs of coolant and oil mix of gray gunk..,
,I need oil so I pulled the cap off and saw the same gray under it also!
<mud welcome!
