mud flaps (no flares, no running boards) toyota part number?
Vermont, USA
Can anyone confirm the correct part number for Toyota mudflaps for a 1992 FJ80 with no flares and no running boards?
Any good aftermarket options?
No, but I just bought a set of used mudflaps for flares and no running boards. Too bad I don't have flares! Subscribed.
76603-60030, 76604-60030, 76608-60020, 76607-60020 I think.
are the rear correct - can anyone confirm?
link to a schematic of rear mud flaps. Those parts numbers listed above (KennyBob) jive but I would call
I am in the same boat...putting together the 80 after re-finishing the paint and de-flaring and just realized I need some different flaps.
PM me if anyone needs flaps for flares off a 92'
This is my ultimate goal as well. Although I may never end up putting new flaps on. Currently deflared but no body work or paint done yet.
If I cant find any at the junk yard in Sac I may just DIY some or see if some other Toyota trucks could be retrofitted (base model no-flare 3FEs seem kinda rare). Hard to drop my winch savings on mud flaps but I dont want to sling rocks on the paint/body work I just spent so much time and effort on
Front and Rear mud flap part numbers above worked - I just did the install.
I ordered them online from Olathe Toyota in Ks 2/8/2019 and they arrived a few days later. The folks on the phone were really helpful.
76603-60030 Front Mud Guard - no flare 1
76604-60030 Front Mud Guard - no flare 1
76608-60020 Rear Mud Guard - no flare 1
76607-60020 Rear Mud Guard - no flare 1
90159-60510 Screw W Washer Tapp 4 (my 80 had some but not all of these - so I wound up with a two spares - you might order 6 to be safe)
90189-06196 Grommet Screw 8 - (my 80 had some, but not all of these - some old ones cracked on install - cheap to just replace them)
90159-60416 Screw W Washer Tapp 8
Now I just need to find someone to weld up the holes from the flares....
Ya, Olathe easy to deal with and best prices too. I got these knock-offs on order from Amazon ($10/pair), same height but 1" narrower, will post results in a couple days. Burned through my body/exterior budget at this point but would much rather have gone with OEM. The no-flare application is pretty straightforward so I hope I can get by with these for protecting the paint
1905211
They do the trick!
She needs a bath...
