MPG woes
New Jersey
I've been watching my MPG slowly decrease over the last year from 12 to 7.6 MPG on my scan gauge. I have a 96 LX on 35's. Ironman front bumper, Sean rear bumper, home made roof rack, crum sliders. All the heavy stuff added well over 2 yrs ago.
Things I've done as either regular PM or in part because of the poor gas mileage.
Was throwing EGR code so I replaced vac lines, bad vsv valve, all gaskets as well as cleaned throttle body and intake. Did not pull and send out injectors.
Checked tire pressure, cleaned MAF sensor.
Replaced rotted exhaust with magna flow y pipe and second cat. Cat back borla exhaust. New O2 sensors.
Set timing to factory specs.
Rebuilt rusted E brake and made sure the brakes were not hanging up.
Pulled EFI fuse to reset.
The thing runs smooth, can't figure out where to go next... Any thoughts?
The computer can lie to you, have you calculated you actual milage when you fill up? Adding some injector cleaner at your next fill up would be a good place to start.
Have you actually done he math on paper? If 7.6 is actually correct, fuel injector service may be in order. This service is pretty inexpensive.
It's possible that the coolant temp sensor is out of the proper range and sending an erroneous signal to the ECM.
A quick & dirty calc is 7.6 X 20 = 152
Are you get over 150 miles per tank?
Sorry for the delima...
Does your scan gauge know you're driving on 35's??? Unless you've changed your gearing, you're traveling a lot further than the driveline thinks.
FWIW.
Finally burned through a full tank(sort of). I used an app that uses your gps for an accurate calculation. My final mileage 235 + a few more. Light wasn't on and i needed to fill for a camping trip tomorrow but it was close.
Found a great free app called Vezma, way easier that figuring it out in my head. So if the gas light comes on around 5 gallons left I'm north of 11.75 mpg, >293 a tank. I'm happy.
I've known Kevin for a while now and I don't think I'd consider him cute...then again, he does have a "40 driving hat."
Nope, still not cute. Secure in his masculinity, sure.
The mpg stuff can often be summed up in what is probably one of my favorite Land Cruiser pictures.
Is there a way to add a really big tank, like 75 gallons so that I "think" I am getting great MPG per tank ? If my wife knew I was getting crappy MPG she would cut me off.
:rolleyes::eek::eek::rolleyes:
I'm almost embarrassed to admit that I got 16.4 mpg out of my last tank of gas (I check every tank usually average over 15). 165k miles, F/R bumpers and sliders/33s. I have almost the perfect commute, though - miles of 50-60 mph driving with no stoplights. I also started using 100% gas and correct for the tire size (it's only about a 5% difference, though) and I'm seeing about a 1 mpg increase over the 10% ethanol stuff. I also drive it easy. I'm old and don't care about driving it fast - I have a 911 for that.
I'm getting 13.5 to 14.5 pretty consistently on my 97, I do need to run some injector cleaner thru the tank but I'm not up terribly upset with the MPG.
I would be replacing the 02 exhaust sensors as there a service item and run rich rather then lean when they get old it's the way there set up to burn fuel rather then valves. :)
