MPG low since battery change
Kent England
I changed the battery for a new one roughly the same time as I had the rear heater pipes modification, while doing the heater pipes I disconnected the front O2 sensor (we only have one O2 sensor here in the UK) since then my fuel has dropped from aprox 200 miles on a tank, to aprox 170 has anyone any ideas what might be wrong? when I did the heater pipe mod, I did accidently run the engine for 15 mins without the O2 sensor plugged in, not sure if that has done any harm?
Wow....if you're only getting 200 miles per tankful (normally) then you certainly can not afford to lose any gas mileage.
Is it all uphill there....or what?
I run on LPG wqhich is slightly different MPG but didnt want to confuse matters by saying I run on LPG.
I have heard that disconnecting the battery can cause problems with MPG and also does disconnecting the O" sensor can cause problems.
Perhaps I should disconnect the battery again, how long do you have to leave it disconnected to clear the ECU?
