Moving my fj40 for the first time
I bet you would have issues moving if you sat for 35 years! Bleed the clutch system. Then check the adjustment on the release lever. Clutch plate could be sticky, could be rust on the pressure plate. Check the tranny and transfer fluid levels. Drire it around the block a few times to loosen stuff up.
Reverse has no synchronizer, so this is normal. So, if it was idling in neutral without the clutch in, it is gonna grind. Depress the clutch pedal, shift into a gear (this will stop the flywheel and input shaft from spinning), then shift into reverse, then ease off the clutch like you would doing a regular take-off. It could be other issues. It is normal to see quite a bit of reverse-gear grinded away, when you open up an old Land Cruiser transmission.
Wouldn't a 77 have a 4 speed tranny with all gears synchronized. No synchro one R or 1st with the 3 speed.
Have never met a vehicle with a synchronized reverse.
It was grinding with the clutch in. In would not go into reverse without going to 1st gear then to reverse.
I almost never shift into reverse from neutral. Into 1st, then reverse, otherwise it grinds. Mine is a 1974.
^^^^ this.
At the very least, I would expect a full flush of the brake and clutch fluid after 35 years. You may even have to replace the brake and clutch masters. If you do, go full OEM. On that note, a full fluid change everywhere would be a good idea. Don't be surprised if you need a carb rebuild, sitting that long.
