Moving Fenders
Olympic peninsula WA
Well I finaly got my front SOA done and got my fenders moved up a few inches. I just sectioned about 4 inches out of the skirt and welded it back together. Almost ready for GSMTR.
What did you do where the fender meets the tub? It almost looks like you slide them up and forward, is that right?
lookin nice bud
did you reattach the bottom of the fender to the cowl somehow (stock bracket?)
malphrus
Where thye fender meets the tub I just had to drill a new hole in the tub but i used the factory holes in the fender to mount it.
The fender isnt actualy atached to the bib. The skirt is bolted to the fender in 2 places and the skirt still has the top 10mm bolt that holds the skirt to the bib.
You can see how much they moved from the support.
The rears dont actualy rub the top of the rear wheel well. you can see the Sharpie line where i had to trim the rear edge of the opening but not the top. At least till I get some 38s.
what are you doin with the hood hold-downs now?
malphrus
I just drilled a hole in the corner of the bib for the hook of the latch to go into.
And YES the u-bolts have been cut off.
