890man
I noticed my 55 running a little warmer than normal a week ago but now its getting worse. Its normally at the first bar on the stock gauge but now its running at the second. This morning, I used the heater but it would run cold while I was in traffic and the temp went high. When I hit the freeway or higher rpm's I would get heat back and the temp would go down but not quite get to normal temp. The thermostat is about 6 months old and the radiator was flushed and tested at that time too. Could the impeller on the water pump start to fall apart and not pump as well or do you think the thermostat could be bad. Timing is good but I haven't checked compression. Not quite sure if there could be a problem with the head gasket. The oil psi is normal as indicated by an aftermarket gauge.
Thanks
I should also add that I just got my carb back from a jimc overhaul. I found out that I have a vaccume (sp) "retarded" dizzy so I just plugged that off at the carb and the dizzy. I'm just using mech advance. For some reason this was never a problem before the rebuild when it was hooked up. This was the only "change" made to the truck.
Thanks
