Motor mounts??? OR U-Joints???
Cedar Park, TX
I have searched the threads and havent found a definite answer to the issue I am having. So I thought I would reach out to the trusty mud members.
When I push or release the accelerator pedal I get a jerking or clanking sound. I was told by a stealership mechanic that it was the motor mounts but was wondering if anyone else had similar symptoms. Neither the mounts or jounts are cheap so I would like to increase my odds by choosing the most common fix first.
Sounds like something abruptly tightening up in the drivetrain when you give it gas.
I know next to nothing, but I had a mysterious drivetrain clunk that all but vanished when I tightened up all the cables on top of the engine (tranny/kickdown cable, accelerator/cruise cable). Give that a shot. Least it can do is make your truck feel infinitely more responsive.
Sounds like an easy check. I will give it a try. Thanks.
You'll have to provide more information. Does it happen while driving or just sitting in the driveway? Where does the sound come from? If you can reproduce the noise while in park, it's probably not a u-joint.
U joints are the easiest to check first. Any movement at all in the joint or yoke means they are bad and will cause clunking. Just grab the driveshaft by hand and try to wiggle it. I find it is best to leave vehicle in neutral to make sure the driveline is not in a bind and get under it to check them. Obviously chok the wheels before doing this so as not to win the Darwin prize. Just my .02
I would agree with the mechanic. It will be the driver side motor mount. I have busted my twice in my 60 and now in my 80. The engine torque over to the passenger side and what happens is when you are wheeling the bumps on the climbs force the issue. It get torn apart from the engine torqueing over. I am planning to replace mine with two old school 40 series hockey puck motor mounts with a thu bolt. Problem solved. I believe ATF(power steering fluid) will help break those down over time. Easy to check. Put a jack under the motor and start to raise it slowly. Better it you raise just the driver side of the motor, maybe a wood block on the oil pan flange. It will show itself quickly. The clanking you hear is the exhaust pipes moving around and hitting things/ supports and stuff from the motor mount flexing/ not supporting. i did it all day long at the Cruiser Crawl. Sounded like I lost the rear bushing on the front control arm, the clank was so loud and violent, every time I shifted into/out of park.
No it is not reproduced in the driveway in park or neutral. Only when there is tension on the drivetrain while in motion and pressing the accelerator or depressing it. I can duplicate the sound at will if I press, let off, press, let off. It is a single "clang" each way.
Its driving me nuts!
Have you tried greasing the universals and slip yolks? Have you inspected the universal joints and slip yolks?
Typically, older FJ80s have a clunk do to the amount of slack in the entire 4WD drivetrain. If it sounds like someone is hitting a steam pipe with a small screwdriver, then I would suspect dry or possibly failing joints in the driveline. If it sounds like a dull thud I'd say it's about normal.
Mine started thumping around 40K miles. I have tried a variety of things to eliminate it. Keeping the driveline properly lubed keeps it to a minimum. I have slightly more than 40K miles on mine after 19 years. It still thumps, bumps, and groans. I've learned to make the radio louder.
It's pretty hard to identify a noise on the web. Get on a creeper with a flashlight and a large screwdriver or prybar. Give everything a good shake and twist and look for cracks or play. While you are at it, check the torque on all the nuts. Good luck.:cheers:
This:
On 91-92's (without the viscous coupler in the t-case), some "clunking" can/should be considered "normal".
it is your driver side motor mount
If his motor was moving enough to make a thud when it hit the mount, the fan hitting the shroud would wake up the neighbors. It was pretty obvious when mine let go some years back.
