Motor mount bushing - need help finding replacement
Wilmington, North Carolina
We are trying to locate replacements for rear motor mounts used on a small block Chevy conversion. See photos below. These are located between a bracket on the bell housing and the frame. 2 3/4” diameter. 1” thick. Hole sized for 1/2” bolt. Partial metal case. Metal sleeve. Have searched the web to the extent of my abilities. Anyone have an idea where we can find replacements?
You might try toyota factory rear engine mounts... That's what I used on the rear crossmember mounts of my Downey conversion years ago. (followed the instructions) Perhaps @Downey has a good source for similar mounts.
HTH,
Will
