Motocraft Carb help please
I just picked up a 70 fj 40. It has a motocraft carb on it , but I can only get it to run with the the choke pulled. If I open it up then it wants to die . Does anyone know what size jets are supposed to be in there ? Further could vacume leaks be a cause of this problem ? Thanks David.
Welcome to MUD!
The first thing many will tell you is to dump the MotorCraft carb and replace it with a rebuilt stock Toyota carb. Look in the for sale section for this part or on E-Bay. Once you aquire that carb if you are on the east coast send an email to FJ40Jim@aol.com. He is a carb rebuilder in Ohio and does excellent work. If you are on the west coast then Marks Offroad www.marksoffroad.net is the place to send it. Mark is known here as 65swb45.
No one here will know what jets to use for that MotorCraft carb. You can get a factory FSM (Factory Service Manual for your truck from the dealer or from here http://tinyurl.com/fhufk.
Good luck!
I have a motocrap carb on my 73 the price was right it was free sone as I have the money I am changing that but to your ? most likly a vac leak I rebuilt the stock one a few times had same problem it would not run with the choke open turned out that my carb was beond help so I got a carb of a pinto that I had and it fit this is after I fixed a major vac leak in my brake booster. So I would sugjest that it is a vacume leak but also would sugjest a stock asian carb if you can afford one.
i have a motocraft 2150 and it runs great. you just need a good carb guy to rebuild it. mine has smaller jets than a stock 2150. i do not know the size i just trust my carb guy. built correctly it is as good if not better than a stock asian carb. the 2150 is 2 barrell full on. performance levels are much higher than a vacume 2nd barrell. plus it works great off chamber i have seen it run on its side. my point is if you have someone who knows about the ford carb it is a great replacement it works great it is cheap and they are everywere. if you do not know anyone to work on it than just buy a good asain and go with it. it takes a good carb guy to make a carb work on a motor it was not designed to go onto. you must change some things to make it work well. i guess that is why so many people stick with the asian carb buy one from jim bolt it up and forget about it.
Thanks guys . I found that the adaptor plate was loose. I tightened it up and it runs better , but still not doing it with out the choke , so I'll have to track down the vac leak . Thanks again for the reply's.
