I don't know if you have emissions tests in the USA but here in the UK we have to each year on cars that are over 3 years old.
I had a down pipe with CAT inc fitted 1 day previous to the emissions test and I am concerned that the oxygen sensor may have been damaged causing these problems below, I do not have any error readouts on the dash, the car runs fine.
I took the car back today for a retest, it passed the seat belt failure but still failed the emissions, I will add the data below of the test.
FIRST TEST ON 8th DEC ON LPG
engine temp....... Min 60 deg C...................Actual 64 deg C
Fast idle test
CO Max 0.30%.......................Actual 1.05% Fail
HC Max 200 ppm....................Actual 70ppm Pass
Lambda 0.97-1.03 .......................Actual 0.96 Fail
Second fast idle test
CO...................................................Actual 0.003 Pass
HC...................................................Actual 9ppm Pass
Lambda............................................Actual 0.96 Pass
Natural idle test
CO.............Max 0.50%................... Actual 0.58% Fail
SECOND TEST ON 10th DEC ON PETROL
Engine temp Min 60 deg Actual 80 deg
Fast idle test
CO Max 0.30%...................Actual 7.04% Fail
HC Max 200ppm.................Actual 184ppm Pass
Lambda 0.97-1.03.....................Actual 0.80 Fail
second fast idle test
CO.............................................Actual 2.29% Fail
HC.............................................Actual 92ppm Pass
Lambda......................................Actual 0.93 Fail
Natural idle test
CO.........Max 0.50%...................Actual 1.61% Fail
Do you think these readings are consistant? the first test was with LPG the second test two days later was on petrol
The day before I took the car in for an MOT I had a new down pipe fitted inc CAT could it be the oxygen sensor has been damaged and thats why all these reading are way out, I thought you got an error code on on the dash come up if somthing is wrong with the sensor.
Any help would be greatly appreciated
Fast idle test
Natural idle test
Fast idle test
Natural idle test
