More wiring
Oklahoma
Ok guys, I have another question that will probably another one of my oversights from spending too long looking at a wiring diagram. I am wiring my 75 FJ40 that has a 350. I am rewiring the whole thing to remove all of the extra wires left by the PO. I can't seem to get my starter to turn or click or anything. Here is my wiring setup. Out of the starter I have the + cable to the battery, A red 10ga, a green 16ga, and a red 16ga. THe PO spliced the green and red wires into a clump that consists of 2 black and white wires and a red wire. One of the bw wires is 14 ga, the other is 16. The previous wiring connected the red 10ga to the factory white wire that leads to the ammeter. I don't have an ammeter. Where does everything go? The large 10ga wire is now connected to the start terminal of the ignition. I have checked it with a meter and it does get hot when I turn the key. Any suggestions? Thanks in advance.
Zac
The 10 ga white wire from the amp meter is the OEM main feed from the battery to the chassis. Usually it would connect to the battery + lug through a fusible link. It would be OK if it also connected to the starter battery cable lug as long as it has a fusible link.
One BW wire is from the ignition key start position to the starter solenoid. the other (smaller?) wire goes from the same solenoid lug to the + side of the coil and is the ballast resistor bypass wire. This last wire may not be necessary for a GM ignition.
HTH
P_H, although I have seen the BW ballast resister bypass wire, and understand its use, I have never seen it in a wiring diagram, and haven't bothered with it when rewiring my rigs. I guess its main purpose would come into effect when the battery got low for some reason (maybe winching, etc).
But why do you suppose it doesn't appear on the diagrams?
Do most rigs you see have it wired up?
Yah, I'm looking at pre 75 stuff. It seems like the years that used it had an ignitor in there, too. (I don't really know what that is, Charlie.)
Okay guys here is how I have everything set up. I am not using an ammeter anymore so I connected a lead from the battery straight to the ignition switch. I am still using the factory connections so that would be the white and blue wire. For the black and white wire that runs out of the switch to the starter it is connected to the red 10ga wire that a PO used. That wire becomes hot when I turn the key to start, but nothing happens. The battery cable and all grounds have not been touched or removed since I started the rewire, so I'm assuming that they are still okay. Do I need another power source to the starter other than the battery and ignition switch wire?
The black white wire from the ignition switch goes to the spade lug connector on the solenoid. It doesn't need to be 10 ga, so that sounds fishy. You don't say where on the starter you have this wire connected. There only need to be two wires going to the starter: The giant power wire from the battery that goes to the big screw lug and the black white wire from the switch that connects to the solenoid push on spade lug. If you have it wired correctly and it won't run, maybe the starter or solenoid is bad. YOu can easily check the starter motor by jumping across the big screw terminals.
If the wire is getting hot, you may very well have a short. And the ignition switch would be an obvious candidate for a problem.
I do what Pin_Head describes and bypass the ignition system occasionally in order to test compression. I've taken a push button on-off switch and connected to it two 10 gauge wires with alligator clips, pulled the BW spade connected wire, and used the switch device to connect the battery post on the starter with the spade connection to the solenoid.
It is also exciting to do it with a screwdriver.
Oh, yeah. And I just stared at the '75 wiring diagram in the Haynes manual. If it is right, there are 2 white with blue wires to the ignition switch in that year. One comes from the ammeter and alternator, one to the fuse box. Did you get the right one?
You're right, there are two white and blue wires but there are only 4 connectors to the ignition switch, a black white, black yellow, blue red, and white blue. This may be where my problem is, on the diagram it shows 2 white blue wires, but there isn't a factory connection to add another white and blue wire. I spliced them together, which I think may be a mistake, but I don't know where else it would go. I'll post a drawing of what I have done tomorrow.
