So I'm a member of that HUGE 'Mud club: 80 owners with windows that suck.
This is partially about the same old issues and partially about something new, so please read on.
My windows have always been slow. The second row, not so much, but the front row get stuck sometimes, and have to be raised by hand while engaging the motor.
The driver's side was so bad that the window glass would actually pull out of the channel.
So... I took everything apart. I greased the heck out of the regulators, tested the motor, and put it all back together.
Same problem.
So, took it apart again and I replaced all the runs (at about $100 for the OEM set). Still the same problem. The glass would pull out of the channel.
So, my buddy used this evil silicone-based adhesive, and that has so far kept the window from pulling out of the metal channel.
But, when the weather is cold, there is till so much resistance that the window gets bound up and - because the glass won't come out of the chanel - the regulator literally gets pulled apart. I have to pop the rear-most ball-joint back into the fitting in the slider.
So, I have taken the door apart (11th time!), and fixed the regulator. I have regreased the slides and set the window back in the runs.
It's working, but it's really bloody slow. Now (probably because the regulator has been damaged by that force), there's an audible "clunk" when the window begins to lower, and again when it is put back up.
The door frame is straight - no obvious bends or dents that would impede the window travel.
What have I missed? I'm stumped.
And... would it help to spray some silicon lube into the window runs? I am worried that silicon would make the runs expand and hold the window even more firmly - the opposite of what I want.
Same problem.
One of my rear windows was pulling the bottom bracket off. I took it apart, sprayed graphite chain lube on the track (had it layin around) , then had to run it up and down buy hand (no attached to bracket) about 30 times. At first I had to force it down. It gradually got better. I didn't glue the bracket in so that it would pop off instead of damaging the regulater if it ever happens again. I put dish soap on the bracket side of the rubber retainer to put it back together. It has worked great for 2 weeks now. I have searched this alot and found that part of the problem with being slow in the cold is bad grounding and dirty contacts on the switches. I haven't been able to do anything yet but this summer I plan to take them apart one at a time to clean runs and all moving parts and add another ground wire. From what I have read by doing this I will get myself out of this not so exclusive club!!
