So I've got a vibration thats driving me mad and im going to tell you what I know about it and hope you can point me in some new directions to look to help me find it.
1. it happens intermittently, but more often than not. I should say it occasionally goes away for a while
2. it happens between 30-60 but disappears over 60
3. its of moderate frequency and intensity, feeling like its moving the wheel back and forth. a super mild death wobble kind of feel.
4. it happens mostly on throttle but sometimes under decel and coast
5. the engine is running strong but there is a tiny warble to it between 1700-2200. Engine feels pretty strong for 300,000 miles (top end rebuilt) but not as strong as it could be. I'll be doing a compression test when I do the wires and plugs at 300,000 miles.
6. the vibration doesn't appear to be in time with the engine but its hard to tell for sure. If I kick it out of gear when its happening it more or less goes away but i can't say its because of the loss of drive or just because it doesn't do it often under coast. If I kick it out of overdrive to 3rd when its happening it still happens at the same basic frequency. Seems to be vehicle speed not engine speed related, and again its never preset at freeway speeds.
7. the front shaft is a custom DC shaft, I took it out recently and ran center locked and it was greatly reduced, though still mildly present. Im having the front shaft balanced tomorrow to be sure.
8. tires are new and in balance (in theory). before the new tires the vibration was at high speed only (not sure if related)
9. drag link ball joints are good, tie rod joints are starting to look like grease is coming out but they are tight. panhard bushings are good. the TJM castor correction bushings are looking faded and worn. wheel bearings are tight and I can't get any play by jacking up a single wheel and forcing movement out of it.
10. regeared to 4.56 nitro, the front setup is quiet and tight (backlash) and the rear is a little loud but tight. The front pinion moves a good 15 degrees before catching (moves maybe a degree for backlash), the rear is a little tighter at 5-10 degrees. rear could be setup wrong, the front was until corrected.
11. No birf click, seals are good and holding grease.
12. despite castor correction the pinion angle is still high and there is not enough castor
13. I replaced the PS spindle because of spun bearings, the DS spindle is original. One of my working theories is that the axle shaft is vibrating against the brass bushing in the spindle...could this be a thing?
Well thats about all I got. I BOLDED anything I suspect as being the issues. Let me know if you have any insights. I hear that a engine problem like a vacuum leak or air sensor reading can sometimes cause the engine to make a vibration like this but I've kinda ruled out the engine for now.
