More questions about my 95?
GA
I am in the process of installing a Trail Gear 3" IFS eliminator. The truck had a warn winch mount and apparently the previous owner pulled on the right side pretty hard. The frame at the front crossmember on the left side is up a little. Does anyone think that this small amount will effect the front axle? I noticed it when I got the bumper off, you can see the margin between the radiator and crossmember. It's not much, but should I get it fixed before I do the install?
Also has anyone used the 2pc drive shaft in the rear?
I got my front axle from a 85. It still has a trans, transfer and rear axle..would any of it be worth keeping?
I will look a little closer..I just assumed that the winch did it .
The frame is tweaked, found where it had been fixed when I was cutting off the IFS. I had a professional look at it and it's within Toyota specs.
