- Joined
- Feb 8, 2004
- Threads
- 297
- Messages
- 5,834
- Location
- Cloverdale B.C. Canada
- Website
- www.instagram.com
hey! guys! more info about drive shaft angles . this is the theory i use on the front of my spring-over . with the cut and turn to save ya from buying a cv shaft . i also posted this last year on zukiworld (the picks). because there was some debate over there whether you can do this or not .because this is how a bunch of guys set up the rear of our suzuki sidekicks for better driveshaft angle and adding taller lifts than are readilly available from the aftermarket . i think the suzuki has a 3-link (stock) ? so there is no axle wrap . my suzuki has been like this for 3 years with no ill effects .and no vibration . anyways this is how i set up my front shaft . on my spring-over cruiser .and have no vibration problems .anyways here's the pics . P.S. i also did this on the rear .with no track bar and had no vibes but with the 350 and a heavy foot . axle wrap would beat the hell out of the u-joint . i have since then changed the rear angles and run a cv shaft .
Jake S.
Jake S.
