ok, ok.. probably getting boring by now...
so, the last H55F I put in the truck was easy.. before it went in it was stuck. input and output shafts wouldn't spin. Easy fix... I popped open the top cover and the shift forks were not alligned. i shifted the sliders into neutral, put reverse in the disengaged position and threw the top cover back on with the shift forks in neutral. Everything worked. it shifted in all the gears fine.
This one, when i got it, was stuck in what seemed to be 4th (input and output moved 1:1). I popped open the top cover expecting a similar scenareo and was surprised to see both sliders in the neutral positions. when i shifted any of them into a gear the tranny locked up. Could on of th egears (3rd or 4th) be stuck somehow? I thought so being that the tranny had probably sat for a while so I put everything in neutral and tried to break it free.... no dice.
Any advice?
also, I noticed that the gear closest to the transfer case moves back and forth a lot. is that normal? maybe the output shaft is not totally tight and it is not seated properly agains the back bearings?
included are a few pics for what they're worth.
any help is appreciated.
-marco
Any advice?
-marco
