so I may or may not have posted this before and I've seen numerous other threads with similar problems... 97 80 w 261k 285BFG AT . So the rear heat blows perfectly once the thing warms up a bit front is a not so much. Back in June July ish I replaced the radiator with one that could actually flow, the old one was a nice mixture of red and green gooey s*** I did this after a 5plus hr ride to the Bronx from cape cod which was very unpleasant with the heat maxed out and all windows down. At the same time of the radiator swap I removed the factory fan clutch and tossed in a flex a lite fan on a switch. I would only need to turn it on while sitting in heavy traffic for extended periods of time I would usually hover around 184 to 192 while driving with it off. Now I haven't turned the fan on other than to check functionality since late September early October. As of right now I can barely reach 172 driving unless it's a 10 to 20 mile trip and I stop at a light for a minute where the temp may climb to a frightening 179 where I actually start to see some heat from the front. I have changed the thermostat and it made little difference also I did burp the system as well as checked the function of the brittle heater valve thing all seems to be good , I'm assuming that the thermostat isn't opening up fully but Idk for sure. So any suggestions are much appreciated
Thanks
Luke
Thanks
Luke
