more clearance on an sua?
Oklahoma City, Oklahoma
i was just pondering something and i was wondering something about the spring plates on the axle. theoretically if i were to cut this off as if i was doing a spring over and grinded it down such that the bottom of the plate set flush on the axle and then welded it back on wouldn't i gain about an inch of clearance under the axle. i just happen to notice several months ago that there was some space, about 3/4" inbetween the bottom of that plate and the axle. just curious what you guys think. i guess if i get that far i may as well just spring it over. i have never heard of this so i doubt anyone has tried it yet. see what you all think.
my friends call me cornbread!
Not gonna gain you too much...
There is only ~1/2" of material there, and you have to have some "reveal" as your spring center pin needs to insert into the axle. For all the work involved... I would skip it and get a bigger sete of tires :D
Exactly. As well as the ends of the u-bolts. That wrap or whatever on those plates is probably meant to protect the ends of the ubolts, so if you remove all that, you leave the nuts and ubolt threads vulnerable to damage. Get bigger tires, flip the u bolts, do a springover or drive carefully.
Nial
Nial
I think you two are talking about two different things... You are referring to a U-bolt flip kit, putting the u-bolt nuts on the top of the axle...
He is talking about replace his stock spring perches with one that has been modified to hug the house (such as we use for a low spring-over setup).
:D
so what's the down side of flipping thos u bolts and how would you do that? it seems to be fairly complicated to me. yeah it does seem like a lot for nothing.....and i guess if i got that far i may as well spring it over.
