After unloading my cruiser from GSMTR, I noticed the passenger side front tire a little kicked out. I drove it to work for a couple of days (5 miles to and fro) to see if there was any wabble/wander, etc... To my surprise there was none, not even any pulling under braking. However, the tire was gradually kicking out more and more. Jacked it up to check the wheel berings, and noticed a ton of wobble, cool easy fix. NOT! on disassemble the wheel berings prove to be good. WTF? further tear down revealed the top knuckle bering was FUBAR. Still not too bad or expensive of a repair. WRONG again. The trunion stud in the hy-steer arm came out of the steering arm. Not broken, just came out! I am not going to say which manufacturer of steering arms I have, as to not give bad publicity, and I may have caused the failure too. I still don't know how, when or where the failure happened either. Here are some things I noticed on the tear down though. The steering arm was hitting the base of the shock, actually using it as a steering stop (I hadn't noticed that earlier) the shock isn't damaged, but the arm is dented where it was hitting the shock. I am thinking I bound the knuckle berring up, and further in the chain the trunion stud gave way. there is no damage to the knuckle (mini truck part): For some reason I can't post pix at this time, I'll add some later.
