ok, I posted on this earlier but apparently i was to vague. I'm going to try again.
Problem-my 72 FJ is backfiring through the intake and the exhaust. I'm assuming the carb is not adjusted properly.
---I did a compression check and all were normal.
---Installed a rebuilt 1972 AISIN carb from SOR
---TIghtened the bolts to the exhaust manifold.
---Timing is correct (just recently fixed that)
Do you think that there is some other problem with the engine itself, such as a sticky valve or what not. Do you think I should try and adjust the carb myself or take it to my mechanic because I dont want to destroy my new carb....It sucks because I feel as though I'm so close to having this beautiful mobile on the road but i'm not there yet....
RYAN
RYAN
