Monte Carlo rear disk install question
I got my Aussie locker in yesterday. Pretty simple install. Spent more time cleaning and prepping than installing. Anyway, I also spent more time F'ing with my drum brakes than the locker. I have two wheel cylinders (one on each side) that are so stuck that soaking them in oil and beating on them with a hammer and drift wont budge them. Sooo- that was the straw that broke my back. I am ripping them off today and doing the Monte Carlo install. Already have the brackets. Not sure where the money for the rest of the parts will come from, or the time for the install, but I'll eat ramen and go without sleep for a month before dealing with those brakes again.
So, I was reading through the tech links, and Morgans write up says hes using a banjo fitting to the calipers, while other lines I have seen look like they just screw right into caliper (Downey). Can the stock metric banjo fittings be used on the new calipers if I use a standard bolt to bolt the banjo to the caliper? That way I dont have to do any converting between a metric and standard line. I will just buy some metric rubber lines from Kragen and be on my way.
thanks!
Dustin
there is one oddball hose available that matches the metric fittings....don't recall application, but do recall it wasn't stock...which means when you tear one on the trail, the local autodroid store won't have an easy replacement in stock for you....
Doing the stock hoses and re-flaring the tubing with the SAE end is a piece of cake....you are likely going to need to rework hard lines anyways, may as well switch a $2 fitting at the same time....
IIRC, I spent a LOT more on the rubber lines than any other part of the disc brake set up. Calipers were $12.00 each, hoses were $30. I went with SAE lines up to the master and changed the ends as well. My local Carquest has adapter lines with an SAE on one end and a metric on the other if you don't have a flaring tool.
I found that the banjo fittings on the rubber hoses with the metric ends are thicker than the banjo bolts from the monte carlo brakes. I haven't been able to locate a longer bolt. Someone suggested grinding the banjo fitting down. but if it isn't straight you will get leaks. I used the banjo fitting from an 87 cad rear disk. It is a solid block with a female connection. The hard lines from the stock cruiser can be adapted to fit.
Brake lines
Check the tech section (sorry I didnt go look for you). There is a article about the rear disc conversion that has a Raybestos part # for a little hose with metric female on one end and the Monte banjo fitting on the other. I had the same problem with the Monte banjo bolts being too short, but Napa carries longer banjo bolts. Once you get all the parts lined up, it takes less than an hour to get everything together. Check the tech about the use of a porprtioning valve too. I dont run one, and havent had any problems yet (other than the backs locking up before the fronts, but you get used to it). I'll probably put one in sometime, Jegs has them cheap. Oh yeah, if your parts store doesnt carry Raybestos, they should be able to crossmatch the part # in the computer (I know this from experience). IF you need any more specific info, send me a PM. Hodag
use the downey braided lines, there about 80 dollars though and super simple to install from the block on the rear axel to the calipers (there made just for the conversion) i just finsihed doing this conversion. what master are you using, i had a hell of a time with master cyl. i finally went with a 1995 80 series with 4 wheel discs and it bolts right up. good luck, it's an awesome conversion
RDB part numbers
The flex hose mentioned with a metric inverted flare female fitting is a Raybestos BH38194 $9.99 ea. Autozone PN 18650760
The longer metric banjo bolt is a Napa 82703 $3.09 ea. My local Napa had a metal box with every banjo bolt ever offered.
Where do you get calipers for $12 each and which ones are they? Are they loaded or bare? New, rebuilt, or used? My best source in S.Ut. quotes $45 loaded.
