Monte Carlo hose connection problem
Columbia, SC
What to do? The pictures should show my dilemma. The banjo mount part of the hoses are big square blocks, and the mounting area on the monte carlo caliper is round. Which do I grind, the hose end round or the caliper tabs around the mounting surface off?
Thanks for any help!
Jeremy
My banjo fittings were incorporated in the hoses, but I bought them from a hotrod shop. I've not seen "blocks" like those before. But I agree, grind the blocks to fit..
BTW, you still need a copper washer with those, I think.
Whoops! went back and saw them in the first pic. D'oh!
GL
Ed
If you are talking to me, a hotrod outfit, Pete and Jake's is just up the road from me. The Mont calipers are a very standard item on hotrods and I just asked for some SS flex hoses with integral banjo fittings. With the "T" block it was less than $50 for both hoses.
http://peteandjakes.com/parts/parts_dept/stainlessBrakeLines.htm
GL
Ed:beer:
Them are Poser's RDB brackets, BTW:bounce:
Jeremy, you can probably return those to NAPA. They also sell just the banjo fittings with the fitting coming off at two different angles(at least), then the flex hose is a separate part. Mine are one piece, could not tell from your pic whether yours are or not.
GL
Ed
