I've posted about this before....I need some other brains on this. all started off with a carwash; sprayed the engine bay (I know, I know) ended up with a misfire. codes for the TPS and rich mixture. I've since replaced the spark plugs (twice), the wires, distro cap and rotor. Oh, and the TPS, I put a new one on there too. unplugged the battery and cleared the codes. The truck still had a misfire that wasn't consistent and while the TPS code disappeared, the rich mixture came back.
Still I've got a misfire. I thought I had bad plugs so I replaced all of them with Densos, slightly better, but not fixed. #3 plug def looked like it was rich and on it's way to fouled. My next step is to re-replaced the spark plug wires and distro cap and rotor again, hoping I might have gotten crappy parts.
I don't see any signs of a head gasket yet. Coolant looks fine, old, but fine. Oil change looked like used oil, nothing unusual there.
I did not do a leakdown / compression test or really check the various vacuum hoses, none of them look really bad.
I did also replace the hose that goes between the air filter and the throttle body. I forget what that guy is called.
so I'm wondering if i've got a bad injector at this point. it seems odd that all of this started when I was a big dummy and blasted my engine bay with water. I'm wondering if it was unfortunate timing of if there's something i'm overlooking that's obvious.
gents, I'm all ears. : )
