Mix and Match Split Transfer Case Gears?
4Cruisers
I've got two split transfer cases, one from mid-'82 and the other from late '84, both have 34mm idler shafts. One will go behind the H41 from an '84 HJ47 (into my '71 FJ40) and I'll sell the other one here on MUD. I'm leaning towards using the case halves, input parts, idler parts, and front output parts from the '82 case and the rest from the '84 case (rear output shaft and gears, rear bearing retainer, and parking brake assembly). That way I can sell the other case with the later case halves, which would mate up to an H41, HJ42, or H55f (the '82 front case half doesn't have the provision for the 5th gear oiler cup).
Will the mix and match of gears (idler shaft gers to rear output shaft gears) cause any issues I need to be aware of?
Well, I'm no expert, but I'm pretty certain they will tell you to not to mix and match gear sets
Well, maybe I should use the shafts and gears that came together as a set and just swap the case halves.
I realise it has been some time, but did you end up running different case halves? It seems the PO of my BJ60 had someone do that during a manual shift transfer / H55F conversion.
Thanks
EO
Pretty sure if you match the idler shaft size you can switch case halves. I have transmission and transfer case from a 3/82 FJ40. Bought from the guy parting the cruiser. I ended up the tube and frame if came out of. He was someone like a lot of here who have tons of parts so know that it's from the 82. I dated the transfer case to 3/83. But 3/83 the dash would have had a 4WD light. There is no provision on the front half of the case to mount the switch. I also
couldn't see a fifth gear oiler a 10/82+ would have had. Besides not good practice would be careful mixing gear sets. Possible it could be noisy or not even being a match. I have never verified it by tearing a few cases down but I think US got feeling ours had a lower low range because of the H42 verses H41/H55F with the lower first gear. Plus 3.70:1 diffs verses 4.11:1 most markets got. Just too bad instead of 3.70:1 diff gears Toyota would have switched to 16" rims.
Thanks for the replies. I have the case apart now and see no unusual wear (only the idler gear thrust washers have nasty black corrosion all over them) so will just go ahead and keep running it as-is.
