Mission Accomplished
TACOMA,WA 98445
IMG_0138.webp IMG_0169.webp IMG_0170.webp I recently
converted my 93 FJ80 into a part time 4wheel drive and front ABS kit from Mark's 4WD adaptor
here are com pictures
PICT0017.webp IMG_0176.webp IMG_0170.webp IMG_0169.webp IMG_0138.webp tly converted my 93 FJ80 into a part time 4wheel drive and front ABS kit from Mark's 4WD adaptor
here is another project the Detroit Locker into the rear Diff 4.56 gear, I was gonna put the E-Locker But it's not a direct fit so I have to sell it let me knowPICT0013.webp PICT0014.webp PICT0010.webp PICT0002.webp PICT0001.webp who wants to buy it. The next project will be a tough dog 4" lift from Australia (affordable one) 20" rims 35" tires and lock right in the front (again affordable locker) ARB is out of picture
It would not be that hard to modify the axle housing to accept the e locker.I did on both the front and rear housings on my truck.But nice job on the part-time kit install.That is one I want to do next on mine.
Your transfer is the HF2AV correct? And you replaced the center diff with that spool and eliminated the viscous coupler? How would you rate the quality of those AVM hubs? What was the main reason you converted to part time? This mod is something I am considering.
buy a large bearing separator from harbor freight cost about $25 look for a cheap press on craigslist, I got one for $40 and water pipes for installing and the important one a case of cool bear, cheers
  • Like
Reactions: den
