Missing frame bushing/mount?
Colorado Springs, CO
So I was looking in my garage today and I found this:
Immediately I though, oh that's a shock mount... So I started hunting around and they were all there. Then I started looking at the frame mount/bushings... What are they even called?
(ignore my missing bump stops, they are on order...)
Turns out, these appear to be missing on BOTH sides... Can anyone confirm for me that this is where this mystery piece came from? Also, anyone got a part number so I can order replacement?
Finally, how big of a pain in the ass is this going to be? Is it worth it? All of the other frame mounts are intact.
-Patrick.
Looks more like a sway bar link end to me. Check those.
Those body mount bushings are just sandwiched in as shown. Mine are the same as in your pic. My first thought was shock end pin and bush as well. Its not left over from a past lift install is it?
Otherwise some of the other body mounts have a bolt and similar bushing but are usually double nutted.
That't not a frame/body bolt. Those will always have to nuts on them-- one against the bushing and then another one to lock the first nut in place. That's how Toyota did it on the 80 series (and other previous series trucks).
The position you are point to (#5 in the schematic) is supposed to be that way. It has a screw in the center embedded deep.
The body mounts will have this type of set-up (you can see the nut and then the 2nd lock nut on top of it):
What you are holding looks like the top of the sway bar bracket either front or rear. I'd check there if you haven't messed with it in a long time.
I knew you guys would pull through... I checked the sway-bar links though (rear), and they don't seem to have anything missing. They are actually slightly smaller than the piece I found.
Also, the front sway-bar looked to attach to the frame via TRE's and not whatever this piece might be.
It's pretty close to the same size as the top end of the shock mount in the front, although a little smaller. I'm wondering if it was sitting in the engine bay or some dark crevice from the PO and somehow I jiggled it out?
Either way, I'll keep digging and let ya'll know if I figure it out.
Or radiator bracket? Could also be from the vibration isolator thingy that hangs from the transfer case or crossmember? (I removed mine so can't remember too well.)
Top of shock could also be another option... Good call.
