Missing bottom engine cover from a gifted 97 land cruiser
Mississippi
I know these are 12mm bolts from a youtube video I watched. But will these work for the engine cover?
Bolt link
I believe this is the engine cover that is needed to cover the AC, fan, and alternator belts underneath as pictured but I am also not 100% sure.
There should be an "Under Engine Cover" (P/N 5144160190) that provides some protection to the parts you mention. As I recall it is held in with 4 (M8?) x 12mm head bolts that have good size washers on them. I believe this cover also plays a part in directing airflow through the engine for cooling performance.
Edit: The correct bolt is P/N 9011908863. Appear to be longer than the ones in your link. Available from your local Toyota dealer.
THANK YOU! Are you using manuals to find these parts/numbers or just searching everything up online? I was able to find the engine cover online prior to the post but I had no clue where I could start with the specific bolts.
Actually I pulled them off a spreadsheet that I use to keep track of the parts I replace on the builds I do. Ultimately the data is researched on Partsouq like @Fj80oregon mentioned.
