misfire
94 landcruiser misfire under load, just replaced wires but didnt do the plugs yet. checked cap and button they are good so is the ignition coil, has anyone had this issue before?
might check the Engine Wiring Harness by the EGR valve on the firewall for any burnt wires; and as well you could test the Throttle Position Sensor if it seems to be more of a dead spot/dying rather than misfiring.
Any way the timing could be off from messing with the dizzy? good luck
did u get a misfire code along with the actual misfires? If so, which cylinder is it?
