Misfire troubleshooting
Southport, NC
Still troubleshooting a cyl 1 misfire issue and general rough running 1FZ. Here's what I've done so far using the FSM for the P0300/301 codes as well as P0401/402:
  1. All cyls have compression of 155 to 165
  2. VSV and all vac lines replaced (VSV tested fine but I had a new one and didn't want to have to do that again a month down the road).
  3. Verified resistance and voltage at first 3 injectors - all consistent and in spec.
  4. Replaced EGR and modulator (P0401 and P0402 codes were present and have gone away - though I have not done any lengthy road tests yet - still runs too rough).
  5. Downstream 02 sensor had a pending code and when inspected, I found a broken/corroded tab, replaced unit, upstream 02 had proper resistance.
  6. Intake plenum cleaned (heavy oil/soot buildup), EGR passages cleaned out.
  7. MAF sensor cleaned
  8. Cap & Rotor & plugs changed (denso std plugs)
  9. Wires checked (3.5, 4.4, 6.2, 5.7, 7.7, 8.6 ohms for 1-6 respectively).
  10. EGR Temp sensor cleaned and passages checked / cleaned.
  11. Harness under EGR checked - covering was slightly worn away and all wires appeared to be in good condition - I did not pull the covering off all of them for an in-depth inspection.
Still working through the FSM but if this looks familiar, I'm open to suggestions on what to test next. I'm tempted to throw wires and injectors at it but would like to have removed all other possiblities before doing injectors..
Tools R Us has written, more than once, to listen to the injectors fire.
Mechanics Stethasscop on each one to hear if there is a difference.
You can also check resistance on the O2 wires to the ecu. Also, the ground wire to each injector. Which you may have already done?
Downstream O2 has nothing to do with engine tuning, only monitors cat performance.
Is the injector firing, listen for the click, should sound the same as the rest.
Is the main harness tied on place, especially to the peg by the EGR pipe, so it cant touch?
EGR 401/402 likely has nothing to do with it and can be turned off with a 4.7k ohm resister.
Your step 9 seems wacky... Resistance of spark plug leads will (should be) in the kiloohm range - these are resistive wires.
So, presumably you are misreading your meter.... My #6 (longest lead) was about 20kohm with the others sequentially lower in value.
cheers,
george.
Items 1,8,9,and 11 are the ones that CAN cause a constant mist on one specific cylinder. The others would likely cause RANDOM misfire. I would concentrate on wiring. Power to the injector is constant, and each injector is triggered individually by the ECU.
