Mirror on Driver Door Exploded!
Rust Free Arizona
Today while sitting in a parking lot there was a very loud "pop" outside the door. It didn't really sound like from the Cruiser, but then the mirror started flopping back and forth on the door. When I inspected the situation the entire mirror assembly can be lifted off the pivot peg! The noise must have been the spring assembly breaking in the pivot. I looked in the shop manual and it looks like this can't be serviced so I bet I will need to buy an entire mirror assembly. Has anyone seen this before? Or better yet, has anyone ever fixed a broken mirror pivot?
I haven't been on the site for a while because the Cruiser has been trouble free since I replaced the head gasket and front and rear main seals. Still not a single drop of a leak! For about 20,000 miles before the head gasket blew it used a quart of oil every 4,000 miles. After the fix (and a valve job) it now goes 5,000 miles and I see no change on the dip stick! Milage also went from 12 to 14 :D
I also put on new rotors and the 100 series pads. This made a HUGE difference and I would recommend it to anyone who needs to replace rotors!!
I think you should double-check the FSM about that thing with your mirror; what you have there is a "sniper". Easly remedied by moving to another parking lot. Or state.
Search...search... the DS mirror wobble/falling out is common, and there is an easy fix using epoxy. Basically the plastic threaded part that receives the screw has cracked, and the two upper tabs that hold the mirror to the motor assembly have broken off - when all three things occur the mirror falls out and dangles from the wiring harness. Do not simply oveertighten the screw in the lower mirror assembly, it will not help. Remove it, lift the mirror out, and see what you have left. The search will also reveal certain 4Runner mirrors will fit if you are looking at a boneyards, but usually these can be fixed with a dab of glue.
m.
Ditto on the common problem. I just used a generous amount of silicon around the attachment points and wrapped it up with a bungee cord and towel (on the face of the mirror to apply direct pressure) to set and all is good now.
