I've got a 1994 with an appears to me, original motor. Currently at 317,000 miles. It consumes very little oil and runs well. Compression test is 150PSI even, across all cylinders - at 3500' elevation. Oil comes out smooth every oil change, with no milky color. Coolant is consumed a small amount, there are some apparent drips on the side of the motor near the oil cooler. Recently replaced water pump, with no sign of leaks from there. Additionally, when i start it up, i sometimes hear air moving through the heater core. I suspect a minor head gasket leak which is allowing air into the system.
so, I intend to replace the head gasket, along with most of the other engine gaskets, Vacuum lines, coolant hoses, belts, and freeze plugs. Based on the numbers i'm getting from compression test, along with how smoothly the engine runs, and the fact it has plenty of power to tow (camper + camping stuff, or 5 guys + snowmobiles) from town up into the mountains, i'm not very inclined to embark on expensive engine rebuild at this point.
I'm mostly interested in fixing the air in my heater core issue, as i'm concerned that any leak could shift from minor to major relatively quickly. I'm usually within an hour or two of home, with my other car serving for road-trip usage.
What else would you guys recommend i do while i have this thing torn apart, that wont blow up my budget?
