- Joined
- Jan 20, 2008
- Threads
- 33
- Messages
- 173
- Location
- Grand Junction, Colorado
- Website
- www.rockymountainextreme.com
Hey guys, my '92 FJ80 has a few minor electrical issues that I'd like to fix. I have searched out each one and found some leads, but I'm looking for more info, if possible. None of these things are big problems, but more of inconveniences that I'd like to take care of. I'll break them down to help define them.
1, Dash Lights; I have no instrumentation lighting. The shifter positions light up and other lights like the diff lock, brake light and check engine light work, but the bulbs that display the gauges do not light up. My dimmer is turned all the way up, all fuses are good.
2, Cruise Control; It will power on and off, at least the light on the dash will light up and then turn off when the button is pushed. Beyond that, nothing. If you try set the cruise, nothing happens. The very first time I used it right after buying the FJ80 it worked for about 3 seconds, the turned off and never worked again. I read about a solenoid, but thought that applied to FZJ's. Again, all fuses are good. Any help there?
3, Heater Blower Control; The heater blower works fine on all settings but the highest. If you set on the highest setting it barely moves any air. All the other settings blow the correct amount, I figure this is probably an issue with the switch.
That's all I have for now, if anyone else has had these problems and taken care of them, I'd love to hear how. Fixing those minor things would make driving the FJ80 a much better experience. TIA!
