And on the pump/pulley......I used a reman from a mid 80's GM pickup. The main difference is where the return fitting comes out and which direction it points. Mine comes out of the back of the pump and points forward, but I run a cooler, so that worked out great.
The reman (about $50) does not come with a hub (press-on) or a pulley. The GM one is very narrow compared to the width of the Toyota grooves/belt. I used a Volvo 240 DL hub and pulley and although it is slightly narrower than the Toyota belt, it is a lot wider than the GM pulley and seems to work just dandy for me.
Your '74 should have a two-groove harmonic balancer, one wide and one narrow. You will also need a two groove waterpump pulley and spacer.
I don't know who's pump/box mounts you are going to use or if you are going to fab something, but I used Bill Dorry's brackets and I'm really happy with them. Best part is that they don't use the head bolts for mounting.
GL
Ed
