mini truck sluggish
Need pertinent information...like engine type, mileage, what has been replaced prior etc..
What else have you done? Why did you replace anything in the first place?
Details details ( :
Any time I had engine trouble and started "hunting" to find the problem. I would 1st do a proper tune up and an inspection of the ignition system and timing and if possible. It's cheap to do a tune up IMO and may not fix your problem. But it will rule out, start you off in the right direction, and it'll run that much better once the problem is fixed.
