Mini Truck Dissasembly Question
I have removed the cone washers and hubs. The next step says remove the outer spindle nut. I don't see one. I have a round piece with holes in it and 3 star shaped screws. Any ideas or help?
If it is a '79-85 mini, it looks like this:
The spindle nut is the big (54mm) nut on the spindle. Bend back the lock tab in the circle first.
I can't post a pic until tomorrow. However, mine doesn't look like the one in pin heads post. It doesn't have that large spindle nut. The axle came off an 85 mini truck. I wonder if it could be something else?
If is another front axle and was working with the minitruck, would it work on my 72 FJ40. It has the passengers side differential but seems to be a bit wider(maybe 2 inches). What is the best way to find out what kind it is?
Paronoid56
You're the man! Thats what I have. Will it be a problem using it with the auto locking hubs? Anything else I need to know?
Thanks for the help. I hope I am back in business.
yea, switch out those hubs, they are the worst i have ever delt with. they like to unlock by them selfs, and s*** like that.
get some stock asin hubs or at the least, get some warn (they have a life time warentee) you will also need the bolt kit to convert them from auto hubs, you can get the parts at the dealer for less then 20 bucks.
it consists of four 54mm nuts, two larger washers, and two locking washers. If the dealer pulls up the exploded diagram for a truck / 4Runner with manual hubs these parts should be easily identifiable.
the upper nuts on this pic
