I installed a mini-truck brake conversion about 20 years ago. I'm jumping into the front end to reseal everything and properly shim the knuckles. IOT remove the brake caliper, I had to open up the brake connection (circled in blue) to remove it from its bracket (circled in red). That was an unnecessary PITA and now I'll have to add brake bleeding to the job.
Does anyone (or everyone) just put a notch in the bracket (in red), so they don't have to open up the brake lines to get the caliper off? Alternatively, since I have to bleed them anyhow, is there a one piece flexible brake line that I can replace the two piece hard and soft line?
Thanks....
Thanks....
