mini p/s install ????
elizabeth,co
i got the brackets from bill dorry.
on the bracket that the BOX mounts to there are no holes to mount the box.there are holes to mount it to the frame but none for the box to mount to bracket.is this normal?did everybody elses bracket come this way?
if so where should i drill.eyeball it ,measure it?what. with my luck im gonna drill it wrong and be screwed.lemme know what you guys did.
shawn
They come without holes so htat you can locate the box optimally for your installation. There are a couple of issues to consider when you locate your box:
The PS box is 3/4 inch longer than the manual box. To deal with this, you can either space your steering column out rearward from the firewall, shorten the shaft or locate the box forward and shorten the drag link.
With larger tires (33-35 inches) there is possible interferance between the tire and Pitman arm in a tight left turn. You may want to locate the drag link close to the frame to minimize contact.
Basically you want to mount the box, steering column and linkage first, test it out and then drill the holes after checking everything twice.
Just, as in two hours ago, finished my mini conversion. I have a 1980 so your steering shaft is different i.e. it has to cut or replaced. On my install, I bolted the mounting plate to the frame with two bolts. Sat the box on top, connected the rag joint to the box and found the best location that 1) allowed for a linear relationship to the steering shaft and 2) made sure that the output shaft of the box (Pitman arm gear) was perpendicular to the frame. Mine ended up being that the box was equidistant from the left and right side of the mount (if you were facing it from the DS) AND the gear box mounting base'e edge ran right on top of the mount's edge on the side closest to the front fender i.e. closest to you if you were looking at. All steering linkage is hooked up and it is a perfect fit.
juke
