Mini Disc Conversion Questions
San Antonio TX
OK, I got the axle out and was removing alot of the grease and noticed there is a slight sharp edge on the inner lip of the birfield. If the pic works you will see where I am talking about. Is this a problem? I was feeling around on the joint itself and couldn't find or see any areas that were worn or scarred. Could this just be from the factory?
Also, While doing a mini conversion, when you take the drums off you can just remove the steering arm and lower bearing and pull the whole assembly off, Can you do this with the disc axle if you rebuild all components first? Lastly, I did not find any shims on this axle at all. Should there be some?
Thanks
Kevin
Oh yeah, and don't laugh at my work stand, It's all I had that would support the weight of the axle while I took it apart....
OK, then lets say it's the inner rim of the knuckle... on the bottom towards the inside
THere is no birfield in the picture, it is the knuckle.
Clean it up first, very hard to insp components when they are covered in rusty grease. Then post a picture with an arrow or your finger pointing to what you are talking about.
Sounds as is you just need to blend the edge with a file.
It is entirely possible that at one time a fing birfield joint failed and tore things up inside that housing, creating the sharp edges that you are talking about. As has been suggested, take this thing apart, keeping shims with the respected steering arm or lower knuckle bearing piece, clean everything, and see what is going on.
Good luck!
-Steve
Thanks, I will clean it and take a better pic, I 'm worried what Poser is saying may be true but there is no other evidence of damage. On the shims, There are none below the steering arm, nothing, nada,, zilch. It doesn't appear that it has been removed but, who knows? Is it possible that no shims were needed? This is a junkyard axle from an 84 mini and the truck appeared to be in pretty good shape,
Thanks
Anything is possible....but it is likely that someone has been into that axle before you got it....who knows what they did, or if they even had a clue about what they were trying to do.
Good luck!
-Steve
OK, here is a better pic of the "lip" ? on the knuckle. I think it is that way from the factory because it is facing the outside? if ya know what I mean.
Still one question remains unanswered tho. Is it possible there were no shims required under the steering arm?
Nah, the lip only goes around the bottom edge, I broke off a small piece on the bottom right and you can see where it picks up again about midway up on the right hand side. If it was wearing or rubbing something , wouldn't the lip or groove be from the outside in and not the inside out? make sense? I'm confusing myself now?
It's just leftover material that didn't get milled off when the knuckle was machined. No worries, but if it were mine, I'd grind that crap off so I didn't slice my hand open on it whilst digging for birfield shrapnel trailside.
Order a rebuild kit from Kurt (cruiseroutfitters). It will come with all new shims. Then just make sure to set your preload correctly when you put it all back together. Depending on your level of motivation, borrow the knuckle centering tool from someone and knock yourself out.
....Also, While doing a mini conversion, when you take the drums off you can just remove the steering arm and lower bearing and pull the whole assembly off, Can you do this with the disc axle if you rebuild all components first? Lastly, I did not find any shims on this axle at all. Should there be some?
Thanks
Kevin
Yes, you can do the exact same thing on the disc axles, pull the steering arm, losen the bottom bearing cap, remove the wipers, remove the birf clip & the hub and take it off. Watch the brakelines... I often modify the backing plate so you can unbolt the junction, that when you can unbolt the caliper (2 bolts), and swing it along with the junction out of the way for repairs ;)
Cool, I already have the rebuild kit, just taking my time tearing it down, only have about 1 hour an evening before the honey-do's kick in.... I'll keep ya posted.
