Cruiserdrew
On the way there
So I've been rebuilding my FJ40 from the frame up for 5 months now. Most recently I have installed a new side cover, FJ60 distributor, FJ60 coil/igniter, FJ60 starter, Jim C rebuilt carb, and adapted my rear harness (from a 76) to run 71 tail lights.
Even though I did not actually start it up, I did hook up the wiring and stuck in the battery. It cranked on the first try! Then I pulled #1 spark plug and grounded the electrode. I have spark! To make a long story short, months of fiddling with it and it actually should work when I get around to getting some gas in it. It also cranked long enough to make oil pressure read on the gauge so the distributor is seated correctly. BTW-the FJ60 distributor has a far superior manner to bolt it down and adjust timing-no stupid clamp.
The only problem I could find with the wiring, is that the rear turn signals are reversed. That should be a 5 minute fix. I highly reccommend the trailer harness adapter if you plan to retrofit old style tail lights. A bit of soldering and fitting and it works like the factory intended.
