Mileage vs RPM's
Western Wonderland
Ok I know that everyone is sick of hearing anything to do with mileage but I had a quick question. Is there an optimal RPM that the 1fz-fe burns fuel more efficiently? I ask this because I tried to do a little test on the last two tanks. I got about 13.7-13.9 MPG on the last few tanks, normal driving, 65-80 on the freeway, and taking no care as to how high the RPM's rev'd. On the last tank I decided to drive 55mph and under, taking care not to rev over 2300 RPM. (I did this for the entire tank.) I averaged about 12.5 MPG. So does the Engine like higher RPM's for more efficient fuel consumption? I know that on my old Toy pickup 22re I was told that about 2800 RPM was the best to stick to. Any insights would be great. Thanks
Well, it's not a 1FZ, but my 3FE absolutely hates low RPMs.
I've been trying to get better mileage than my normal 10.5 by going lighter on the skinny, but I ended up getting 9.1 on this past tank.
:confused:
An old hot rod buddy told me once that if you run your rpm's so the engine produces max torque at those rpm's, that's where your best mileage will be. Not sure if it works on the old tractor motor but I like to run around 2400 to 2700 at highway speed and I consistantly get 16+mpg in the summer months. Best ever was 18.7 in the UP of MI for two tanks of fuel. Must have been good gas. Shell if I recall correctly.
Mileage
Hello,
You probobly shouldn't judge your mileage by one tank of gas regardless of drivings style, and here is why:
There are too many variables. Wind, traffic, how you are using your Power button, and Second Gear Start button (are you using them correctly?), Grade of fuel, Gas Pump calibration, (here is one everybody forgets..) the angle of the pavement you are gassing up at (that might be the biggest factor of all next to your city driving habits), and so on.
I only say this because I am an obsessive person and mileage is one of the thingsI've been obsessing about years before it became expensive.
I have a lot more to say about this ,and there was a good thread covering favorable the favorable results of blueprinting and balancing fuel injectors last year.
I just bought a 97 LC with 92k (and locker...thank you) in very very good condition and have pumped up 2x so far. I kept records of mileage, and how much gas I pumped in and calculated averages.
If you write these exact words 'Fishbone Tell Me More' I will post some things about a stategy I am about to undertake regarding increasing my mileage.
But be warned however, that I am very long winded..... So think before you ask.
:confused:
I thought I was the only one that felt like this. I've noticed that if I try to keep my RPM's low in my 3FE it actually uses more gas also.
Ditto, if I drive light footed, I find that the mileage goes down. If I rev the engine higher at take off, (i.e., hard exceleration off the line and let the engine shift more like a stick shift), I actually get better mileage.:confused:
Fishbone's got me all worked up waiting on 'the strategy.'. I keep checking my blackberry at work, come on already...
I always thought that fewer RPM's= lower gas consumption. But the fact is that it just doesn't work out that way.
From other threads I have read there is not a lot you can do for mileage with these big girls. Better airflow in and out has helped with my other vehicles. My VW saw went from 18 to 24 with an intake, chip and exhaust change. For my 3FE there is no chip that works so keeping the motor well tuned and changing the exhaust is at the top of my list. I need to find a GGA (Gas Guzzlers Anonymous) group to my girl off the sauce but no luck yet.
Patience, 40, patience. Fish said he's long-winded. :D
I measure my consumption by the interval I fill my tank. With the onset of winter, I'm filling up every 6 days compared to almost every 8 days. Hopefully, Fish's strategy would also work here where winter is ...
A gas motor has a vacuum (hint, hint.....vacuum!!!!!!!!)
it replaces load with fuel because its trying to creat more vacuum
A Diesel (hint, hint..........!) has no...NO vacuum
The manufacturer has ALREADY told you the optimum RPM and GAVE YOU THE DARN GEARS FOR IT!!!!!
read your torque curves people
most optimum RPM for HP????....4,000
most optimum RPM for Torque????..........3,200
(somewhere close to that because those are PEAK, YOU, contrary to popular belief do not know whats best for your motor......your motor does)
a 6BT Cummins???.......just off idle to redline
New Cummins Turbo Diesel
Another engine choice is the new, high-pressure, common-rail injection, High Output Cummins Turbo Diesel engine, producing 305 horsepower at 2,900 rpm and 555 lb.-ft. of torque at 1,400 rpm. The torque provides a towing capability of 23,000 pounds (GCVWR).
Also available is a standard Cummins Turbo Diesel with 250 horsepower at 2,900 rpm and 460 lb.-ft. of torque at 1,400 rpm.
The Cummins Turbo Diesel has average major overhaul intervals of 350,000 miles. An inline six, the new 5.9-liter Cummins has 30 to 40 percent fewer parts than typical V-8 diesels, enhancing durability and reliability.
Dear Lord people!
ALL GAS MOTORS USE MORE FUEL UNDER LOAD
REALLY??????????
:flipoff2:
Duh. What we don't quite understand is why the 3FE, even with barely any load, hates low RPMs.
The optimum RPM at which to drive your 80 will depend on the load (HP) required to cruise at the target speed.
You will need a RPM vs load (Hp) vs efficiency graph. It will look like a 3d map.
There is not one magic rpm for all load conditions.
At slow speed (i.e. low power output) the efficiency is much lower than average, due to a larger percentage of the available heat being absorbed by the metal parts of the engine, instead of being used to perform useful work. Gasoline engines also suffer efficiency losses at low speeds from the high turbulence and head loss when the incoming air must fight its way around the nearly-closed throttle; diesel engines do not suffer this loss because the incoming air is not throttled. Engine efficiency improves considerably at open road speeds; it peaks in most applications at around 75% of rated engine power, which is also the range of greatest engine torque.
(THANK GOOGLE)
